소개
You must remove the top assembly in order to remove the display. This guide will also show you how to remove the top assembly to access the display mounts and cables.
필요한 것
Position the laptop so that the bottom enclosure is facing upward.
Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
Use an opening tool to carefully pry up the rubber pads.
Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
Flip the laptop over and swing open the display.
Lift the edge of the keyboard closest to the trackpad up.
Carefully disconnect keyboard ribbon cable from the laptop.
Remove the keyboard.
Keep the device positioned where it sits on the bottom encasing with the display open.
Locate the four 1.9mm screws used to attach the display brackets to the bottom enclosure of the device.
Use a Phillips #00 Screwdriver to remove the four screws.
다른 5명이 해당 안내서를 완성하였습니다.
