소개
Replacing the RAM module with a larger capacity one is a easy way to speed up your computer. Make sure the new RAM module is compatible before you install it.
필요한 것
Position the laptop so that the bottom enclosure is facing upward.
Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
Use an opening tool to carefully pry up the rubber pads.
Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
Flip the laptop over and swing open the display.
Lift the edge of the keyboard closest to the trackpad up.
Carefully disconnect keyboard ribbon cable from the laptop.
Remove the keyboard.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Excelente… easy and simply.
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
Kyle Brock - 답글
