주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Yoga 11S Top Assembly Replacement
필요한 것
  1. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 1 단계, 이미지 1/3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 1 단계, 이미지 2/3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 1 단계, 이미지 3/3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Remove Keyboard: 2 단계, 이미지 1/1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 4 단계, 이미지 3/3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Landon Epps
회원 가입일: 03/26/15
982 평판
안내서 5개 작성하였습니다
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G11
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
ggr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 3,127
