주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Yoga 11S Trackpad Replacement
필요한 것
  1. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 1 단계, 이미지 1/3 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 1 단계, 이미지 2/3 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 1 단계, 이미지 3/3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Remove Keyboard: 2 단계, 이미지 1/1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad Yoga 11S Trackpad Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad Yoga 11S Trackpad Replacement: 4 단계, 이미지 3/3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: 5 단계, 이미지 1/2 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: 5 단계, 이미지 2/2
    • Position the removed top encasing where it sits on the keyboard and trackpad. The inside of the top encasing should be upward facing.
    • Use a plastic opening tool to lift the retaining flap to disconnect the ZIF connector.
    • Gently pull the trackpad cable out of the socket.
  6. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 6 단계, 이미지 1/1
    • Locate the four 1.6mm screws that connect the trackpad to the top housing.
    • Use a Phillips #00 Screwdriver to remove the screws.
  7. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 7 단계, 이미지 1/1
    • Flip the top assembly over so the keyboard is on top.
    • Gently push the trackpad out of its position.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Landon Epps
회원 가입일: 03/26/15
982 평판
안내서 5개 작성하였습니다
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G11
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 22
전체 시간: 4,116
