주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Z570 Disc Drive Replacement
필요한 것
  1. Lenovo IdeaPad Z570 Disc Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Disc Drive Replacement: 2 단계, 이미지 1/1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Disc Drive Replacement: 3 단계, 이미지 1/1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Disc Drive Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Z570 Disc Drive Replacement: 4 단계, 이미지 2/2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Disc Drive Replacement, Disc Drive: 5 단계, 이미지 1/1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Disc Drive Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Z570 Disc Drive Replacement: 6 단계, 이미지 2/2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Disc Drive Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad Z570 Disc Drive Replacement: 7 단계, 이미지 2/2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Disc Drive Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Z570 Disc Drive Replacement: 8 단계, 이미지 2/2
    • Gently remove the disc drive from the left hand side of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Lopes
회원 가입일: 03/08/19
610 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 UMass Dartmouth, Team S1-G6, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 701
