주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Z570 Screen Replacement
필요한 것
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: 2 단계, 이미지 1/1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: 3 단계, 이미지 1/1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 4 단계, 이미지 2/2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 6 단계, 이미지 2/2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 7 단계, 이미지 2/2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 8 단계, 이미지 2/2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: 9 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 9 단계, 이미지 2/2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad Z570 Screen Replacement: 10 단계, 이미지 2/2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: 11 단계, 이미지 1/3 Lenovo IdeaPad Z570 Screen Replacement: 11 단계, 이미지 2/3 Lenovo IdeaPad Z570 Screen Replacement: 11 단계, 이미지 3/3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: 12 단계, 이미지 1/1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: 13 단계, 이미지 1/3 Lenovo IdeaPad Z570 Screen Replacement: 13 단계, 이미지 2/3 Lenovo IdeaPad Z570 Screen Replacement: 13 단계, 이미지 3/3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Lopes
회원 가입일: 03/08/19
610 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 UMass Dartmouth, Team S1-G6, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 1,044
