주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A1000L Battery Replacement
필요한 것
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: 1 단계, 이미지 1/3 Lenovo IdeaTab A1000L Battery Replacement, Battery: 1 단계, 이미지 2/3 Lenovo IdeaTab A1000L Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: 2 단계, 이미지 1/3 Lenovo IdeaTab A1000L Battery Replacement: 2 단계, 이미지 2/3 Lenovo IdeaTab A1000L Battery Replacement: 2 단계, 이미지 3/3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: 3 단계, 이미지 1/3 Lenovo IdeaTab A1000L Battery Replacement: 3 단계, 이미지 2/3 Lenovo IdeaTab A1000L Battery Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Peter Newell
회원 가입일: 04/15/14
627 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014 회원
CPSU-REGAN-S14S7G21
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 17
전체 시간: 22,982
