주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A1000L Power and Volume Buttons Replacement
필요한 것
  1. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 1 단계, 이미지 1/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 1 단계, 이미지 2/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 1 단계, 이미지 3/3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 2 단계, 이미지 2/2
    • Locate the volume control button on the right hand side of the tablet.
    • Now, gently slide the volume button upward to remove.
  3. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 3 단계, 이미지 1/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 3 단계, 이미지 2/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 3 단계, 이미지 3/3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next with the same screwdriver remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  4. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 4 단계, 이미지 1/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 4 단계, 이미지 2/3 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 4 단계, 이미지 3/3
    • Locate the power button on the top right hand corner of your device.
    • Gently slide the button up to remove.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Lauren Pluim
회원 가입일: 04/22/14
428 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014 회원
CPSU-REGAN-S14S7G21
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 5,357
