주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A2109 Battery Replacement
필요한 것
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab A2109 Battery Replacement: 2 단계, 이미지 2/2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: 3 단계, 이미지 1/2 Lenovo IdeaTab A2109 Battery Replacement: 3 단계, 이미지 2/2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: 4 단계, 이미지 1/2 Lenovo IdeaTab A2109 Battery Replacement: 4 단계, 이미지 2/2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: 5 단계, 이미지 1/2 Lenovo IdeaTab A2109 Battery Replacement: 5 단계, 이미지 2/2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Kyle
회원 가입일: 04/22/14
581 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 회원
CPSU-REGAN-S14S7G19
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 8,261
