주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A2109 Camera Assembly Replacement
필요한 것
  1. Lenovo IdeaTab A2109 Camera Assembly Replacement, Camera Assembly: 1 단계, 이미지 1/1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Locate the small indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool in this indentation, under the middle of the cover as shown.
    • Pry up and push to remove the cover.
  2. Lenovo IdeaTab A2109 Camera Assembly Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab A2109 Camera Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Camera Assembly Replacement: 3 단계, 이미지 1/3 Lenovo IdeaTab A2109 Camera Assembly Replacement: 3 단계, 이미지 2/3 Lenovo IdeaTab A2109 Camera Assembly Replacement: 3 단계, 이미지 3/3
    • Pry open the front and rear faces using a plastic opening tool.
    • It may take a little force to separate the front and rear faces of the device.
    • Slide the plastic opening tool to one corner.
    • Place another plastic opening tool into the gap and slide it to the opposite corner as shown.
    • Pull the rear cover up and back to separate it from front face of the device.
  4. Lenovo IdeaTab A2109 Camera Assembly Replacement: 4 단계, 이미지 1/1
    • Slide the rear camera ribbon from the system board.
    • Pull up on the black plastic lock on the system board for the front camera and slide the ribbon out.
    • Now, you are ready to remove the front and rear facing cameras.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abigail Bertholf
회원 가입일: 04/14/14
521 평판
안내서 1개 작성함
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 회원
CPSU-REGAN-S14S7G19
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 9
전체 시간: 582
