주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A2109 Digital Board Replacement
필요한 것
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: 1 단계, 이미지 1/1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab A2109 Digital Board Replacement: 2 단계, 이미지 2/2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: 3 단계, 이미지 1/3 Lenovo IdeaTab A2109 Digital Board Replacement: 3 단계, 이미지 2/3 Lenovo IdeaTab A2109 Digital Board Replacement: 3 단계, 이미지 3/3
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: 4 단계, 이미지 1/2 Lenovo IdeaTab A2109 Digital Board Replacement: 4 단계, 이미지 2/2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: 5 단계, 이미지 1/2 Lenovo IdeaTab A2109 Digital Board Replacement: 5 단계, 이미지 2/2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: 6 단계, 이미지 1/1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 04/22/14
565 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 회원
CPSU-REGAN-S14S7G19
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,026
