소개
Use this guide to replace the digital board.
필요한 것
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller plastic cover that runs across the top of the device.
Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Once it is unscrewed, remove the rear cover
This may take a little force to get off but with enough force it should pop right off
Use a blue opening tool to pry it open
Slide the tool to one corner then grab another tool and slide it to the opposite corner
Pull the cover up and it will come off
다른 4명이 해당 안내서를 완성하였습니다.
