주요 콘텐츠로 건너뛰기
Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement
필요한 것
  1. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, Battery: 1 단계, 이미지 1/1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 2 단계, 이미지 2/2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 3 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 3 단계, 이미지 2/2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 4 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 4 단계, 이미지 2/2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 5 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 5 단계, 이미지 2/2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 6 단계, 이미지 1/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 6 단계, 이미지 2/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 6 단계, 이미지 3/3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 7 단계, 이미지 1/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 7 단계, 이미지 2/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 7 단계, 이미지 3/3
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 8 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 8 단계, 이미지 2/2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 9 단계, 이미지 1/2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 9 단계, 이미지 2/2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 10 단계, 이미지 1/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 10 단계, 이미지 2/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 10 단계, 이미지 3/3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, WIFI/GPS Antenna: 11 단계, 이미지 1/1
    • Once the system board has been removed, you can access the WIFI/GPS antenna.
  12. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 12 단계, 이미지 1/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 12 단계, 이미지 2/3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 12 단계, 이미지 3/3
    • Insert the blue prying tool at the corner of the antenna. Pry up slowly, and move it across the antenna.
    • There is an adhesive holding the antenna in place, so it may take a little bit of force and movement to take off the antenna.
    • The antenna falls out easily once fully pried out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bcohen
회원 가입일: 04/14/14
436 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 회원
CPSU-REGAN-S14S7G19
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 3,322
