소개
Use this guide to replace the WIFI/GPS antenna
필요한 것
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Remove two black 3mm Phillips #00 screws.
Remove three silver 1.8 mm Phillips #00 screws.
Once the system board has been removed, you can access the WIFI/GPS antenna.
다른 2명이 해당 안내서를 완성하였습니다.
