주요 콘텐츠로 건너뛰기
Lenovo IdeaTab S2109A-F Battery Replacement
필요한 것
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Battery Replacement: 2 단계, 이미지 2/2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: 3 단계, 이미지 1/1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caelen
회원 가입일: 01/16/15
228 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G3
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - 답글
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 1,547
