주요 콘텐츠로 건너뛰기
Lenovo IdeaTab S2109A-F Speaker Replacement
필요한 것
  1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Speaker Replacement: 2 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Speaker Replacement: 2 단계, 이미지 2/2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Speaker Replacement: 3 단계, 이미지 1/1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Speaker Replacement: 5 단계, 이미지 1/1
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F Speaker Replacement: 6 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Speaker Replacement: 6 단계, 이미지 2/2
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F Speaker Replacement: 7 단계, 이미지 1/2 Lenovo IdeaTab S2109A-F Speaker Replacement: 7 단계, 이미지 2/2
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F Speaker Replacement: 8 단계, 이미지 1/3 Lenovo IdeaTab S2109A-F Speaker Replacement: 8 단계, 이미지 2/3 Lenovo IdeaTab S2109A-F Speaker Replacement: 8 단계, 이미지 3/3
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F Speaker Replacement: 9 단계, 이미지 1/1
    • Pull up on the connection to disconnect the speakers.
결론
Caelen
회원 가입일: 01/16/15
228 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 440
