소개
This is a quick guide on how to remove and replace the battery.
필요한 것
동영상 개요
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
YOU HAVE TO REMOVE THE KEYBOARD. First, the keyboard is glued with two sided tape so it feels like you are breaking something getting it off. It also has clips all around don't try to undo the bottom until last. Second, there are 3 screws under the keyboard that need to be removed. The third screw was hidden under a Lenovo label, thanks Lenovo. Thirdly, there is no need to disconnect the keyboard harness.
