주요 콘텐츠로 건너뛰기
Lenovo Ideapad 110S-11IBR Speaker Replacement
필요한 것
  1. Lenovo Ideapad 110S-11IBR Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Speaker Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 2 단계, 이미지 2/2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Speaker Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Speaker Replacement: 5 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 5 단계, 이미지 2/2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Use your fingers to gently remove the speaker connector from its socket.
  7. Lenovo Ideapad 110S-11IBR Speaker Replacement: 7 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 7 단계, 이미지 2/2
    • Unscrew the four 4mm Phillips screws.
  8. Lenovo Ideapad 110S-11IBR Speaker Replacement: 8 단계, 이미지 1/1
    • Pull the right speaker carefully under the ribbon cable.
  9. Lenovo Ideapad 110S-11IBR Speaker Replacement: 9 단계, 이미지 1/1
    • Lift the the left speaker to finish.
결론
Andy Rangel
회원 가입일: 09/20/17
119 평판
안내서 1개 작성함
University of North Texas, Team S6-G1, Thomas Fall 2017 University of North Texas, Team S6-G1, Thomas Fall 2017 회원
UNT-THOMAS-F17S6G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 679
