주요 콘텐츠로 건너뛰기
Lenovo Ideapad 110S-11IBR Touchpad Replacement
필요한 것
  1. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: 2 단계, 이미지 2/2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: 3 단계, 이미지 2/2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 4 단계, 이미지 1/1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 5 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: 5 단계, 이미지 2/2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Touchpad: 6 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 7 단계, 이미지 1/1
    • Remove the clicker assembly.
  8. Lenovo Ideapad 110S-11IBR Touchpad Replacement: 8 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
결론
Samaa Aldar
회원 가입일: 04/06/19
181 평판
안내서 2개 작성하였습니다
IUPUI, Team S11-G11, Wilson Spring 2019 IUPUI, Team S11-G11, Wilson Spring 2019 회원
IUPUI-WILSON-S19S11G11
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,308
