주요 콘텐츠로 건너뛰기
Lenovo Ideapad 110S-11IBR Webcam Replacement
필요한 것
  1. Lenovo Ideapad 110S-11IBR Webcam Replacement, LCD: 1 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the eleven 3.7 mm screws from the bottom of the Chromebook.
  2. Lenovo Ideapad 110S-11IBR Webcam Replacement: 2 단계, 이미지 1/1
    • Remove the back cover, showing the internal components.
  3. Lenovo Ideapad 110S-11IBR Webcam Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool or spudger to push the battery's bundled connector out of its socket.
  4. Lenovo Ideapad 110S-11IBR Webcam Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove six 4.6 mm screws that connect the screen hinge assembly.
  5. Lenovo Ideapad 110S-11IBR Webcam Replacement: 5 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Webcam Replacement: 5 단계, 이미지 2/2
    • Remove the frame from the screen utilizing the iFixit opening tool.
  6. Lenovo Ideapad 110S-11IBR Webcam Replacement: 6 단계, 이미지 1/1
    • Remove 4-2.7mm Philips size 0 screws from the screen utilizing the iFixit screwdriver.
  7. Lenovo Ideapad 110S-11IBR Webcam Replacement: 7 단계, 이미지 1/1
    • Remove the screen.
  8. Lenovo Ideapad 110S-11IBR Webcam Replacement, Webcam: 8 단계, 이미지 1/1
    • Remove the connector from the webcam.
  9. Lenovo Ideapad 110S-11IBR Webcam Replacement: 9 단계, 이미지 1/1
    • Use a plastic opening tool to free the camera assembly from the adhesive.
결론
Samaa Aldar
회원 가입일: 04/06/19
181 평판
안내서 2개 작성하였습니다
IUPUI, Team S11-G11, Wilson Spring 2019 IUPUI, Team S11-G11, Wilson Spring 2019 회원
IUPUI-WILSON-S19S11G11
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 464
