주요 콘텐츠로 건너뛰기
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
필요한 것
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 4 단계, 이미지 1/1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 1/1
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 8 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 8 단계, 이미지 2/2
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 9 단계, 이미지 1/2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: 9 단계, 이미지 2/2
    • Gently pull the Wi-Fi card out of place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Daughters
회원 가입일: 09/20/17
405 평판
안내서 2개 작성하였습니다
University of North Texas, Team S6-G1, Thomas Fall 2017 University of North Texas, Team S6-G1, Thomas Fall 2017 회원
UNT-THOMAS-F17S6G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 1,253
