주요 콘텐츠로 건너뛰기
Lenovo Ideapad 120s-14IAP LCD Screen Replacement
필요한 것
  1. Lenovo Ideapad 120s-14IAP LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Open your laptop and insert the Jimmy into the space between the plastic screen cover and the laptop back.
    • Run the Jimmy along the edge and carefully pull the cover outward as you go.
    • Once you have completely detached the screen cover from around the edges, gently pull and remove the cover.
  2. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove four Phillips #0 screws from the corners of the LCD screen to detach the screen from the mounts.
    • The screen is still attached by an electrical connector at the bottom, so don't completely remove the screen quite yet. Be ready to catch the top, as it will want to fall forward.
  3. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: 3 단계, 이미지 1/1
    • Lean the LCD screen forward to expose the display connection near the base.
    • Remove the display connector by placing your thumbnail under the connector latch, and gently pull the LCD screen.
    • The LCD screen can now be removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle P Sumpter
회원 가입일: 09/17/19
363 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,183
