주요 콘텐츠로 건너뛰기
Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement
필요한 것
  1. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: 3 단계, 이미지 1/2 Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: 3 단계, 이미지 2/2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
결론
Robert Harper
회원 가입일: 09/17/19
156 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 771
