주요 콘텐츠로 건너뛰기
Lenovo Ideapad 120s-14iSp Motherboard Replacement
필요한 것
  1. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14iSp Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: 3 단계, 이미지 1/2 Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: 3 단계, 이미지 2/2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14iSp Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
  5. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
    • Pull on the plastic film to remove the display connection cable.
  6. Lenovo Ideapad 120s-14iSp Motherboard Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the connections for the right speaker.
    • Using tweezers, disconnect the connections for the battery.
    • Using tweezers, disconnect the connections for the CMOS battery.
  7. Lenovo Ideapad 120s-14iSp Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
  8. Lenovo Ideapad 120s-14iSp Motherboard Replacement: 8 단계, 이미지 1/2 Lenovo Ideapad 120s-14iSp Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove seven 2.5 mm Phillips #0 screws from the motherboard.
    • Slide the motherboard out of the laptop chassis.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Daniel Lopez
회원 가입일: 09/17/19
172 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 37
전체 시간: 2,814
