주요 콘텐츠로 건너뛰기
Lenovo Ideapad 310-15IKB Fan Replacement
필요한 것
  1. Lenovo Ideapad 310-15IKB Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Flip the laptop over so the back panel is facing up.
    • Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
  2. Lenovo Ideapad 310-15IKB Fan Replacement: 2 단계, 이미지 1/1
    • Remove the panel from the laptop.
  3. Lenovo Ideapad 310-15IKB Fan Replacement: 3 단계, 이미지 1/1
    • Gently unplug the connector for the fan from the underside by pulling it gently.
  4. Lenovo Ideapad 310-15IKB Fan Replacement: 4 단계, 이미지 1/1
    • Flip the laptop upright and open it with the screen facing you.
  5. Lenovo Ideapad 310-15IKB Fan Replacement: 5 단계, 이미지 1/1
    • Use an opening tool to remove the keyboard cover panel, exposing the motherboard and fan.
  6. Lenovo Ideapad 310-15IKB Fan Replacement: 6 단계, 이미지 1/1
    • Remove the single 3 mm screw holding the fan in place using a Phillips #0 screwdriver.
  7. Lenovo Ideapad 310-15IKB Fan Replacement: 7 단계, 이미지 1/1
    • Remove the fan by pulling it away from the motherboard and then upwards out of the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Be careful to align the fan screw holes in place.
Sergio Burchell
회원 가입일: 02/20/22
145 평판
안내서 1개 작성함
University of Kentucky, Team 1-1, Kaufmann Spring 2022 University of Kentucky, Team 1-1, Kaufmann Spring 2022 회원
UKY-KAUFMANN-S22S1G1
4 회원들
안내서 5개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 207
