주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-15ABR Back Panel Replacement
필요한 것
  1. Lenovo Ideapad 320-15ABR Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Back Panel Replacement: 2 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 2 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 2 단계, 이미지 3/3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Back Panel Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Back Panel Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Back Panel Replacement: 4 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 4 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 4 단계, 이미지 3/3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Back Panel Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 5 단계, 이미지 3/3
    • Remove the back panel by pulling it up and away from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Anurag Deb
회원 가입일: 10/31/18
1,048 평판
안내서 3개 작성하였습니다
댓글 한 개
How Is solved Twisted screw and broken inside the frame
For laptop ip520
mohsen JUVE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 130
전체 시간: 13,298
