주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-15ABR Fan Replacement
필요한 것
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: 2 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Fan Replacement: 2 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Fan Replacement: 2 단계, 이미지 3/3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Fan Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: 4 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Fan Replacement: 4 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Fan Replacement: 4 단계, 이미지 3/3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Fan Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Fan Replacement: 5 단계, 이미지 3/3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: 6 단계, 이미지 1/1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: 7 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Fan Replacement: 7 단계, 이미지 2/2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: 8 단계, 이미지 1/1
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: 9 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: 9 단계, 이미지 2/2
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: 10 단계, 이미지 1/1
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: 11 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Fan Replacement: 11 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Fan Replacement: 11 단계, 이미지 3/3
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: 12 단계, 이미지 1/1
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: 13 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Fan Replacement: 13 단계, 이미지 2/2
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: 14 단계, 이미지 1/1
    • Replace the new fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katie Marie Schoeling
회원 가입일: 10/22/18
204 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 42
전체 시간: 5,170
