주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-15ABR Hard Drive Replacement
필요한 것
  1. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 2 단계, 이미지 3/3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 4 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 4 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 4 단계, 이미지 3/3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Gently lift up the hard disk from the left.
  7. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 7 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 7 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 7 단계, 이미지 3/3
    • Do not lift hard drive straight up as it risks breaking the connection port.
    • Carefully pull the hard drive away and out of the connection port.
  8. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 8 단계, 이미지 3/3
    • Detach the bracket from the hard drive by pulling the bracket edges apart.
결론
다른 25명이 해당 안내서를 완성하였습니다.
Anurag Deb
회원 가입일: 10/31/18
1,048 평판
안내서 3개 작성하였습니다
댓글 4개
What is the maximum thickness of the replacement Hard Drive/SSD.
Drew Howden - 답글
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
TheSolderSnake -
@TheSolderSnake You might want to use google to see the variation in 2.5” laptop drive thickness before making such a confident statement. ;)
Ben - 답글
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
Paul Hucik Jr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 170
전체 시간: 24,153
