소개
This guide will show you how to remove and replace the hard drive for the device.
Before you start replacing the hard drive, make sure to turn the device off, remove the battery and disconnect the laptop from any power source.
필요한 것
Carefully pull the hard drive away and out of the connection port.
다른 25명이 해당 안내서를 완성하였습니다.
댓글 4개
What is the maximum thickness of the replacement Hard Drive/SSD.
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
