주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-15IAP Hard Drive Replacement
필요한 것
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Franco Criscola
회원 가입일: 01/30/20
901 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 51
전체 시간: 1,311
