주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB Fan Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Fan Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Fan Replacement: 2 단계, 이미지 2/2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Fan Replacement: 3 단계, 이미지 1/1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Fan Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Fan Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Fan Replacement, Battery: 5 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Fan Replacement, Battery: 5 단계, 이미지 2/2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Fan Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Fan Replacement: 6 단계, 이미지 2/2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Fan Replacement, Fan: 7 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Fan Replacement, Fan: 7 단계, 이미지 2/2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Fan Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB Fan Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB Fan Replacement: 8 단계, 이미지 3/3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
84,853 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 한 개
Very helpful instructions. However, Step 6 indicates that you should remove 5 screws, but really you only need the 2 on the left that are actually connecting the fan to the system board, the rest are unnecessary. In fact, the machine I replaced this on only had the one screw in the top-left.
Jeff Breuer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 819
