주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB Hard Drive Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Hard Drive Replacement: 3 단계, 이미지 1/1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Battery: 5 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Battery: 5 단계, 이미지 2/2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: 6 단계, 이미지 2/2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3/3
    • Disconnect the hard drive from the SATA slot by gently pulling the hard drive to the left.
  8. Lenovo Ideapad 320-17IKB Hard Drive Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB Hard Drive Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB Hard Drive Replacement: 8 단계, 이미지 3/3
    • Use your hands to gently pull the edges at each corner away from the hard drive to remove the hard drive adapter.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Rei Lopez
회원 가입일: 02/11/24
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 12
전체 시간: 40
