주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB RAM Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB RAM Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB RAM Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB RAM Replacement: 2 단계, 이미지 2/2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB RAM Replacement: 3 단계, 이미지 1/1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB RAM Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB RAM Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB RAM Replacement, RAM: 5 단계, 이미지 1/1
    • The RAM is located on the right side of the motherboard above the battery.
  6. Lenovo Ideapad 320-17IKB RAM Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB RAM Replacement: 6 단계, 이미지 2/2
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it to release the RAM stick.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
    • Slide the RAM stick out from the memory module slot.
    • When installing new RAM, slide it into the port at the same angle it was removed and press down until it clicks into place.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Gabriella Maeli Vazquez
회원 가입일: 02/08/24
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 41
