주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB Speakers Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB Speakers Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Speakers Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Speakers Replacement: 2 단계, 이미지 2/2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Speakers Replacement: 3 단계, 이미지 1/1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Speakers Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Speakers Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Speakers Replacement, Battery: 5 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Speakers Replacement, Battery: 5 단계, 이미지 2/2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Speakers Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Speakers Replacement: 6 단계, 이미지 2/2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Speakers Replacement, Speakers: 7 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Speakers Replacement, Speakers: 7 단계, 이미지 2/2
    • Gently pinch the white tab and pull the speaker cable out of its socket.
    • Don't pull on the cables.
    • The speaker connector is located directly underneath the battery.
    • If you can't get the speaker cable out by hand, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  8. Lenovo Ideapad 320-17IKB Speakers Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB Speakers Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB Speakers Replacement: 8 단계, 이미지 3/3
    • Lift the left and right speakers up and disconnect the cables from the chassis to remove the speaker assembly from the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Amy Aquije
회원 가입일: 02/08/24
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 45
