소개
This guide shows you how to replace a Lenovo 320-17IKB touchpad.
Before replacing your touchpad, try updating and reinstalling the touchpad drivers. You will know your touchpad is faulty if your cursor is lagging or jumping after updating/reinstalling your drivers.
Step 1 requires you to remove a part that is glued down. Glue/solder is necessary to reattach this part.
Before beginning, make sure to power off your laptop completely and disconnect it from any external power source.
필요한 것
Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
Pull the Wi-Fi card straight out of the laptop.
Use a Jimmy or opening tool to pry and and release the clips that secure the touchpad cover.
Remove the touchpad cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
