주요 콘텐츠로 건너뛰기
Lenovo Ideapad 330-15ARR Fan Assembly Replacement
필요한 것
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 2 단계, 이미지 2/2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: 3 단계, 이미지 1/2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: 3 단계, 이미지 2/2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 5 단계, 이미지 3/3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
결론
Brayden Fleming
회원 가입일: 09/22/22
479 평판
안내서 3개 작성하였습니다
University of North Texas, Team 3-2, Saru Jimmy Fall 2022 University of North Texas, Team 3-2, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S3G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 365
