주요 콘텐츠로 건너뛰기
Lenovo Ideapad C340-API or Flex 14-API webcam repair
필요한 것
  1. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Remove D-Cover: 1 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Remove D-Cover: 1 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Remove D-Cover: 1 단계, 이미지 3개 중 3개
    • Remove the 10 Torx TX5 screws on the bottom case
    • With all screws removed pry off the cover with your fingernails or use a spudger.
    • The cover should off quite easily.
  2. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Opening up and battery unplugging: 2 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Opening up and battery unplugging: 2 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Opening up and battery unplugging: 2 단계, 이미지 3개 중 3개
    • To remove the display assembly we have to take care of four areas
    • At first disconnect the battery before we move ahead. Use a spudger to carefully unplug the battery connector.
  3. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Screen hinge left: 3 단계, 이미지 2개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Screen hinge left: 3 단계, 이미지 2개 중 2개
    • Unscrew the left screen hinge with a screwdriver.
  4. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Right screen hinge and display connector: 4 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Right screen hinge and display connector: 4 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Right screen hinge and display connector: 4 단계, 이미지 3개 중 3개
    • Unscrew the two screws of the right screen hinge
    • Unplug the display connector carefully using a spudger from the right side
  5. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Disconnect the extension board: 5 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Disconnect the extension board: 5 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Disconnect the extension board: 5 단계, 이미지 3개 중 3개
    • The extension board to the left is connected by a ribbon cable.
    • To unplug it lift up the white clip and carefully pull out the cable
  6. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Unplug the Wi-Fi card: 6 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Unplug the Wi-Fi card: 6 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Unplug the Wi-Fi card: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Depending on your model the two wifi connectors may be hidden under a soft rubber pad. Remove it with a pair of tweezers.
    • You can use the tweezers to lift up the wifi connectors from its plug. Be careful not to damage the cables in the process.
  7. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Display removal: 7 단계, 이미지 2개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Display removal: 7 단계, 이미지 2개 중 2개
    • With all cables and connectors removed from the main board you can now gently lift up the hinges and separate display assembly from the rest.
    • Now you have the display assembly only which gives you way easier access to further repairs.
  8. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Screen disassembly: 8 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Screen disassembly: 8 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Screen disassembly: 8 단계, 이미지 3개 중 3개
    • Pry off the flexible bottom cover of the display assembly.
    • You can use a spudger or a guitar pick to do so.
  9. Lenovo Ideapad C340-API or Flex 14-API webcam repair: 9 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair: 9 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair: 9 단계, 이미지 3개 중 3개
    • With the cover removed you will find 4 screws to be removed (red circles) as well as two strips of adhesive (green rectangles) you have to pull.
    • After unscrewing the four screws use a pair of tweezers to pull on the tabs of the rubber adhesive strips.
    • Be patient while pulling and avoid ripping off the adhesive strips!
  10. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Webcam removal: 10 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Webcam removal: 10 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Webcam removal: 10 단계, 이미지 3개 중 3개
    • After you have removed the adhesive the display can be separated from its housing. Be careful with handling as the touchscreen is quite fragile
    • To proceed you have to unplug the ribbon cables like you did before on the mainboard.
    • Lift up the tabs and pull out the cables.
  11. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Inspecting the logical boards: 11 단계, 이미지 2개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Inspecting the logical boards: 11 단계, 이미지 2개 중 2개
    • After removing the adhesive strip you can see that the webcam is divided into 3 logical units:
    • The first board (green rectangle) houses the indicator LED as well as the microphone. The second board (blue rectangle) is just the webcam with the part no. 01HW045. The smallest (red rectangle) seems to be a light sensor board
    • The boards are just glued into place and can easily be pryed out.
  12. Lenovo Ideapad C340-API or Flex 14-API webcam repair, Tinkering and reseating: 12 단계, 이미지 3개 중 1개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Tinkering and reseating: 12 단계, 이미지 3개 중 2개 Lenovo Ideapad C340-API or Flex 14-API webcam repair, Tinkering and reseating: 12 단계, 이미지 3개 중 3개
    • The connectors between the boards especially the ribbon cable (green rectangle) lose connection over time. This is why problems occur.
    • To fix just reseat all connectors carefully!
    • If you bought a webcam replacement just connect all cables as they were before.
    • I used duct tape to create a stronger bond between the components.
결론
You might use double sided tape to glue the display back to its frame.
작성자
2다른 기여자 명과 함께
Fred
3,822 평판
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 36
전체 시간: 1,562
