주요 콘텐츠로 건너뛰기
Lenovo Ideapad Flex 15 Hard Drive Replacement
필요한 것
  1. Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: 1 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Hard Drive Replacement: 3 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 3 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Hard Drive Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Locate the hard drive assembly on the top right hand corner of the Flex 15 based on the orientation of the device in the picture.
  8. Lenovo Ideapad Flex 15 Hard Drive Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 8 단계, 이미지 3/3
    • Begin by unscrewing the four (20 mm) black screws that surround the hard drive’s metal cage.
    • Once removed, remove the black SATA connector by pulling it from the hard drive unit towards the right hand side of the laptop.
  9. Lenovo Ideapad Flex 15 Hard Drive Replacement: 9 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 9 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Hard Drive Replacement: 9 단계, 이미지 3/3
    • The hard drive should be freed from the base of the laptop.
    • There are four (20 mm) black screws surrounding the hard drive from the cage. Unscrew these to free the hard drive from the cage
결론
다른 6명이 해당 안내서를 완성하였습니다.
Brent
회원 가입일: 03/04/16
804 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 23
전체 시간: 6,930
