소개
If you are trying to replace your current hard drive, this guide will walk you through the process.
필요한 것
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Locate the hard drive assembly on the top right hand corner of the Flex 15 based on the orientation of the device in the picture.
다른 6명이 해당 안내서를 완성하였습니다.
