주요 콘텐츠로 건너뛰기
Lenovo Ideapad Flex 15 RAM Replacement
필요한 것
  1. Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: 1 단계, 이미지 1/2 Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 RAM Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad Flex 15 RAM Replacement: 2 단계, 이미지 2/2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 RAM Replacement: 3 단계, 이미지 1/3 Lenovo Ideapad Flex 15 RAM Replacement: 3 단계, 이미지 2/3 Lenovo Ideapad Flex 15 RAM Replacement: 3 단계, 이미지 3/3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 RAM Replacement: 4 단계, 이미지 1/1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 RAM Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad Flex 15 RAM Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad Flex 15 RAM Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 RAM Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad Flex 15 RAM Replacement: 6 단계, 이미지 2/2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 RAM Replacement, RAM: 7 단계, 이미지 1/2 Lenovo Ideapad Flex 15 RAM Replacement, RAM: 7 단계, 이미지 2/2
    • Once open, locate the RAM stick below the fan on the bottom right corner of the Flex 15.
    • At the same time, using two hands, pull both clips away from the RAM module.
  8. Lenovo Ideapad Flex 15 RAM Replacement: 8 단계, 이미지 1/2 Lenovo Ideapad Flex 15 RAM Replacement: 8 단계, 이미지 2/2
    • The RAM stick should start to tilt upwards. Once you see this, pull the stick diagonally towards the top of the laptop.
    • Be careful and do not apply extra pressure on the RAM.
    • If you feel that it will snap, pull the clips apart farther to loosen the RAM connection. Then try again.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brent
회원 가입일: 03/04/16
804 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 3,051
