주요 콘텐츠로 건너뛰기
Lenovo Ideapad Flex 15 Speaker Replacement
필요한 것
  1. Lenovo Ideapad Flex 15 Speaker Replacement, Bottom Panel: 1 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Speaker Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Speaker Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Speaker Replacement: 2 단계, 이미지 2/2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Speaker Replacement: 3 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Speaker Replacement: 3 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Speaker Replacement: 3 단계, 이미지 3/3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Speaker Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Speaker Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Speaker Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Speaker Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Speaker Replacement: 6 단계, 이미지 2/2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 7 단계, 이미지 1/3 Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 7 단계, 이미지 2/3 Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 7 단계, 이미지 3/3
    • Locate the speaker unit at the top left hand corner of the Flex 15.
    • Using the screwdriver (PH1 bit), remove the (50 mm) screws on either side of the speaker unit.
  8. Lenovo Ideapad Flex 15 Speaker Replacement: 8 단계, 이미지 1/2 Lenovo Ideapad Flex 15 Speaker Replacement: 8 단계, 이미지 2/2
    • There is a small white socket which a cable of the speakers is plugged into.
    • Pull the wire off by pulling either sides of the black header (do not pull the wire directly as it could break off).
    • The speaker can be removed carefully.
결론
Brent
회원 가입일: 03/04/16
804 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,052
