소개
If the laptops speakers need to be replaced, this guide will be helpful in order to walk you through the process.
필요한 것
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Locate the speaker unit at the top left hand corner of the Flex 15.
Using the screwdriver (PH1 bit), remove the (50 mm) screws on either side of the speaker unit.
거의 끝나갑니다!
결론
