메인 콘텐츠로 스킵하기
소개
Is the back panel to your device cracked or broken? Consider using this guide to replace the back panel of your laptop.
  1. Turn off your laptop before you begin.
    • Turn off your laptop before you begin.
  2. Remove the nine 6mm screws circled in the picture using a T5 Torx Screwdriver. Remove the two 10mm screws circled in the picture using the same T5 Torx Screwdriver.
    • Remove the nine 6mm screws circled in the picture using a T5 Torx Screwdriver.
    • Remove the two 10mm screws circled in the picture using the same T5 Torx Screwdriver.
  3. After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off. After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off.
    • After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off.
결승점
Isaiah Vang
회원 가입일: 2018년 10월 04일
630 평판
안내서 6개 작성하였습니다
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G6
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 100
