주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If your Lenovo’s Ideapad Flex 4 battery cannot hold a charge, and your laptop dies if not plugged in, use this guide to replace your battery.
  1. Turn off your laptop before you begin.
    • Turn off your laptop before you begin.
  2. Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. After all of the screws are removed, use a plastic opening tool to carefully pry the black cover off.
    • After all of the screws are removed, use a plastic opening tool to carefully pry the black cover off.
    • Remove the back cover.
  4. Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery. Do not pry or pull on the socket itself or you risk damaging the motherboard.
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Remove the three 4 mm screws using a T5 Torx Screwdriver.
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Remove the battery.
    • Remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Isaiah Vang
회원 가입일: 2018년 10월 04일
645 평판
안내서 6개 작성하였습니다
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G6
4 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 28
전체 시간: 664
