주요 콘텐츠로 건너뛰기
Lenovo Ideapad Flex 4-1570 Display Replacement
필요한 것
  1. Lenovo Ideapad Flex 4-1570 Display Replacement, Back Panel: 1 단계, 이미지 1/1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Display Replacement: 2 단계, 이미지 1/1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Display Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: 4 단계, 이미지 1/2 Lenovo Ideapad Flex 4-1570 Display Replacement, Display: 4 단계, 이미지 2/2
    • Use an opening tool to remove the three hinge bezels.
  5. Lenovo Ideapad Flex 4-1570 Display Replacement: 5 단계, 이미지 1/1
    • Remove the four 4 mm screws (two on each hinge) using a T5 Torx screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Display Replacement: 6 단계, 이미지 1/3 Lenovo Ideapad Flex 4-1570 Display Replacement: 6 단계, 이미지 2/3 Lenovo Ideapad Flex 4-1570 Display Replacement: 6 단계, 이미지 3/3
    • Attach a suction handle to the corner of the display, then wedge the blade of a Jimmy between the display and its housing.
    • While sliding the Jimmy around the perimeter, place opening picks in the gap you created at regular intervals.
    • Once you've worked around the perimeter, lightly pull on the suction handle while gently prying with an opening tool until the display releases.
  7. Lenovo Ideapad Flex 4-1570 Display Replacement: 7 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the six 4 mm screws (three on each hinge) securing the hinges.
  8. Lenovo Ideapad Flex 4-1570 Display Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the rubber stoppers in both hinges.
  9. Lenovo Ideapad Flex 4-1570 Display Replacement: 9 단계, 이미지 1/1
    • Remove the black foam over the black and white cords, to the left of the Wi-Fi card, using tweezers.
  10. Lenovo Ideapad Flex 4-1570 Display Replacement: 10 단계, 이미지 1/1
    • Disconnect the black cable near the fan using tweezers.
  11. Lenovo Ideapad Flex 4-1570 Display Replacement: 11 단계, 이미지 1/1
    • Remove the display from the rest of the computer.
결론
Hunter Page
회원 가입일: 02/13/22
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 272
