주요 콘텐츠로 건너뛰기
소개
If you have trouble listening to sounds on your laptop, and the audio sounds distorted, use this guide to replace your audio speakers.
  1. Turn off your laptop before you begin.
    • Turn off your laptop before you begin.
  2. Remove the nine 6mm screws circled in the picture using a T5 Torx Screwdriver. Remove the two 10mm screws circled in the picture using the same T5 Torx Screwdriver.
    • Remove the nine 6mm screws circled in the picture using a T5 Torx Screwdriver.
    • Remove the two 10mm screws circled in the picture using the same T5 Torx Screwdriver.
  3. After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off. After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off.
    • After all of the screws are removed, use the iFixit opening tools to carefully snap the black cover off.
  4. Lift up on each speaker, one by one. The speaker should lift up with ease. Lift up on each speaker, one by one. The speaker should lift up with ease.
    • Lift up on each speaker, one by one. The speaker should lift up with ease.
  5. Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard. Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard.
    • Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard.
결론
Isaiah Vang
회원 가입일: 2018년 10월 04일
645 평판
안내서 6개 작성하였습니다
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G6
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 76
