주요 콘텐츠로 건너뛰기
Lenovo Ideapad Flex 4-1570 Touchpad Replacement
필요한 것
  1. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 2 단계, 이미지 1/1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: 4 단계, 이미지 1/2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: 4 단계, 이미지 2/2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 5 단계, 이미지 1/1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
  7. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Touchpad: 7 단계, 이미지 1/1
    • Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
  8. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 8 단계, 이미지 1/1
    • Disconnect the touch pad chip from the motherboard.
  9. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 9 단계, 이미지 1/1
    • Disconnect the bronze piece of tape from touch pad and set it off to the side.
  10. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 10 단계, 이미지 1/2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 10 단계, 이미지 2/2
    • Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
결론
Isaiah Vang
회원 가입일: 10/04/18
669 평판
안내서 6개 작성하였습니다
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G6
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 539
