소개
Use this guide to replace the lower case on your Lenovo IdeaPad Gaming 3 15ACH6.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
필요한 것
Use a Phillips screwdriver to remove the 10 screws securing the lower case:
Six 12 mm screws
Four 4.5 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the left and right edges to release the remaining clips.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
