주요 콘텐츠로 건너뛰기
Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement
필요한 것
  1. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: 1 단계, 이미지 1/2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: 1 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: 2 단계, 이미지 1/2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: 2 단계, 이미지 2/2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 3 단계, 이미지 1/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 3 단계, 이미지 2/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 3 단계, 이미지 3/3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 4 단계, 이미지 1/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 4 단계, 이미지 2/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 4 단계, 이미지 3/3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 5 단계, 이미지 1/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 5 단계, 이미지 2/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 5 단계, 이미지 3/3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: 6 단계, 이미지 1/2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 2.4 mm screw securing the right SSD.
  7. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 7 단계, 이미지 1/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 7 단계, 이미지 2/3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 7 단계, 이미지 3/3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
Spencer Day
회원 가입일: 09/14/22
59,678 평판
안내서 430개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 4개
Hello u said the wrong m.2 size its not M.2 2230 SSD its a m.2 2242
Matthew Dhanraj - 답글
Thanks for the article... So the right ssd is M.2 2242 NVME
mfarhanfp - 답글
what type of SSD is that?
Gloabl - 답글
Hi! As stated in the introduction, this is an M.2 2242 SSD.
Spencer Day -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 71
30일 전: 277
전체 시간: 6,044
