주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you are having trouble with your computer's battery life, or if your computer will not power on, this is the guide to help solve your problems. There are no tools needed to perform any steps, but be careful in putting the battery back into the laptop.
  1. Flip laptop over bottom side up.
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Use your finger to push the battery switch labeled "2."
    • Use your finger to push the battery switch labeled "2."
  4. Once both switches are unlocked, the battery will release.
    • Once both switches are unlocked, the battery will release.
  5. When replacing the battery make sure the two protruding holes line up with the slot.
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
결론
Casey Zhang
회원 가입일: 2019년 02월 06일
315 평판
안내서 2개 작성하였습니다
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 회원
UCD-LORE-W19S20G5
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 160
